The next generation of Flat Roofing Systems
Approved installers of Topseal GRP Fibreglass roofing Systems
What is a GRP Fibreglass Roofing System?
GRP, (Glass-fibre, Fibre-glass roofing) is a flat roofing system which is now becoming popular in the domestic and commercial sectors. It's stunning finishes have left customers with the satisfaction of having a hardwearing waterproof finish which will stand up to the elements for a minimum of 25 years.
A Chopped strand fibre-glass mat is laid onto the roof and saturated in polyester resin until all of the air has been worked out. It is then allowed to set hard before a final UV protective topcoat (in any colour), is applied, to create a beautiful looking solution to an otherwise un-attractive flat roof.
Our GRP roofs are laid by our in-house trained installers, we do not use sub-contractors.
We travel all over the UK and Western Europe installing our GRP system to roofs, ponds and GRP swimming pools.
Stace Contracts have successfully carried out over 1000 GRP flat roof installs since 1999.
GRP Benefits
Flat Roof problems solved – permanently!
Our super-durable flat roofs keep your possessions safe and dry - and with added flat roof insulation, they can help you save energy and money too.
- Adaptable
- Long-lasting
- Cost Effective
- Durable
- Eco Friendly
GRP Installation
For all Domestic & Commercial Buildings
- Schools, Colleges & Universities
- Submerged
- Paved Terraces
- Factories & Shops
- Apartment & Housing Blocks
- Metal cladded
- Warm Roof Systems
- Pavilions
- Un-insulated
- Hospitals (Solvent-Free)
- Paved Root resistant
FREE no obligation quotation or for further advice
Call Freephone: 0800 779 7059 to find a team in your area!
Or Email us: enquiries@staceroofing.co.uk
Stace Roofing Latest Projects
Just some of our recently completed projects. Please click on the images below to enlarge.
GRP Installation Stages
Click here to see the construction stages of a GRP Roof.
Other Systems:
Kemper is a high quality overlay system which is designed primarily for use where the removal of the existing roof coverings is difficult. It is similar to the GRP system although a fleece mat is used in a more flexible resin composition.
Kemper is designed for larger roof areas such as factories, schools, colleges, universities and other large buildings. It comes in many colours and finishes and also in a solvent and odour free system which is more suited for sensitive locations such as schools and food factories.
Kemper carries a 20 year guarantee and is widely used all over Europe. More information can be found on the Kemper website at www.kemper-system.co.uk
Request Call Back
Just complete your details below and we will call you back at the earliest opportunity
Approved Installers
Stace Roofing are approved installers
of the following products:
GRP was first discovered in the late 1940’s. Its main application was for boat building. Today, it is the standard material for the construction of small craft, water tanks, building cladding panels, roof lights and of course high performance waterproof coatings.
Stace Roofing Green Roofing Systems
We supply and install environmentally friendly green roofing systems. Green roofs provide many benefits, not only to the environment, but also in an aesthetic and economical way.
Find out more |
